Group: DynoMotion Message: 4261 From: toby_rule Date: 3/18/2012
Subject: Initializing KM_Interpreter using KMotion_dotNet
Hello,
I am trying to use the simulate feature of the KMotion interpreter in KMotion_dotNet. How do I initialize the KMotion interpreter without a board attached? I tried doing something like:
.KM_Controller.KM_Interpreter kmInterpreter = new KMotion_dotNet.KM_Controller.KM_Interpreter(0);
But it gave me a fairly non-verbose DMException, which I am attaching below.
I spent quite a bit of time working with the KMotionCNC code (C++/MFC) but that was a couple years ago, and I'm new to the dot net interface. So the solution is probably obvious, but a couple hours searching didn't turn anything up so hopefully you can assist me.
Toby Rule
KMotion_dotNet.DMException was caught
Message=Exception of type 'KMotion_dotNet.DMException' was thrown.
Source=KMotion_dotNet
StackTrace:
at KMotion_dotNet.KM_Controller.KM_Interpreter..ctor(Int32 boardnumber)
at LaserTech.eCut.SimProgramModel..ctor() in C:\Users\trule\Documents\LCM\lcm\ProgramControl\SimProgramModel.cs:line 32
InnerException:
Group: DynoMotion Message: 4262 From: himykabibble Date: 3/18/2012
Subject: Re: Initializing KM_Interpreter using KMotion_dotNet
Could be wrong, but I *think* you want to set the CoordMotion.IsSimulation() property true to enable simulation. I also don't think you need (or want) to explicitly create the KM_Interpreter. Just create the KM_Controller, and it will create the KM_Interpreter for you.
Ray L.
--- In DynoMotion@yahoogroups.com, "toby_rule" <trule@...> wrote:
> Hello,
> Thanks,
> Toby Rule
> StackTrace:
> InnerException:
Group: DynoMotion Message: 4263 From: Toby Rule Date: 3/19/2012
Attachments :
    Hi Ray,
    Thanks for tip tip.  I think the problem my be solved.  Strangely my laptop’s behavior changed between 1:30 am at home  and 9:00 am at work.  Now it’s giving me a message that says it’s a dll loading error. That’s a problem I can solve.
    Toby
    From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of himykabibble
    Sent: Monday, March 19, 2012 1:46 AM
    Subject: [DynoMotion] Re: Initializing KM_Interpreter using KMotion_dotNet
    Ray L.
    > Hello,
    > Thanks,
    > Toby Rule
    > StackTrace:
    > InnerException:
    Group: DynoMotion Message: 4264 From: brad murry Date: 3/19/2012
    Attachments :
      Hello Toby,
      The most common cause of that issue is having your project in the Any PC configuration on a 64bit machine.  Set your solution's build settings to x86.
      -Brad Murry
      Sent: 3/19/2012 5:45 AM
      Subject: RE: [DynoMotion] Re: Initializing KM_Interpreter using KMotion_dotNet
      Hi Ray,
      Toby
      Ray L.
      > Hello,
      > Thanks,
      > Toby Rule
      > StackTrace:
      > InnerException:
      Group: DynoMotion Message: 4265 From: Tom Kerekes Date: 3/19/2012
      Hi Toby,
      Make sure you are using the latest V4.29z code.
      The simplest method is to target your application to be in the C:\KMotion429z\KMotion\Release directory.  Otherwise the correct KMotion DLLs and other files may not be located properly.
      To create the Interpreter object you should do something like:
      public partial class Form1 : Form
      KM_Controller _Controller; //Object to interface with the Kflop
      KM_CoordMotion _CoordMotion;
      KM_Interpreter _Interpreter;
      public Form1()
      InitializeComponent();
      _Controller =
      new KMotion_dotNet.KM_Controller();
      _CoordMotion =
      new KMotion_dotNet.KM_CoordMotion(_Controller);
      _Interpreter =
      new KMotion_dotNet.KM_Interpreter(_CoordMotion);
